How can I remove languages from the initial list of selected languages?
Lets say, I have INDON languages I want to remove.
The reason for this, is i have several reports that thrown an error message in infolog saying “Label @SYS70751 not found in language INDON (report SalesInvoice).”
From the Object Designer: Tools, Language Module, Export. Give it a file name and check the “delete language” checkbox. Let it run, click OK to confirm, and it’s gone.
Daniel is Dynamics Nav MVP. By mistake he posted reply for Ax query.
I can’t think of any other option. Usually it should work. BTW how did you remove the files? Once removed are you connecting using 2 tier? Is their AOS instance running on that application?
