hi I am working on Navision 3.01. This database is multilanguage enabled i.e CaptionML for all the obejcts are present for Sapnish language. Now i want to remove all the captionML from the objets. Doing manully ill take at least a week for all the objects. Is there any way by which this can be done i mean trough code or some standard functionality. Example :- All the fields in customer Table have got CaptionMl for spanish, now i want to remove all the captionML from the customer table fields. Regards
Please explain exactly what you want to do? And why? You got to remove the installed lanugage one by one, by selecting Tools, Language Module, Export and then select language you want to remove (select delete here). Remember to backup you full system first.
