What user rights need to be present so the user has access to everything besides the NAV finance module?
Hi Pete,
It depends on what you mean by NAV finance module? The “finance module” contains a lot of different tables, and often you would need access to part of the finance module, like access to read setup tables etc. Typically you would want to limit access for users to see G/L Entries. Some also limit users to see G/L accounts, but that would prevent them from using G/L accounts directly on sales and purchase orders/invoices.
So a little more information on what you need is required to answer your question. [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Hi Pete
If you are using role tailored client you can run it configuration mode You will be able to add and remove access to the features you need.
