Remove link between Form dataSource
Hello,
I’ve created a form with 2 datasources. AX create link automaticaly. how to remove this link.
Regards
Look into the Join Source property of the form data source…
Thank you Kranthi,
I already tested but its not working. I want to create two independent datasources in same Form. if you have a exemple.pleaze help me.
Thank you.
What is the problem you are facing???
I want to create a form in which I want to display two independent Grid, but AX automatically create a link between the datasource.
Example:
  • I created Table A and Table B (non-relationship between two tables)
  • I created a Form, I drag Tables A and B in the datasource. (not relationship between datasource).
  • I’ve created two grids (Grid for Table A, Table B for GridB).
My Problem: When I click a row in the grid A , automatically a row selected in the Grid B.
thank you.
What is the data source property from Grid B???
this is data source property from Grid B:
In the design - check the data source property of the GridB…
thank you very much,
