Can anyone help me to remove the highlighting the record in the grid when opening the form?
with regards,
Raman S
with regards,
Raman S
Can you please explain it clearly? (may be with a screen shot)
I think he talks about AX grid shows highligted with visual persistence so even unfocus to grid doesn’t remove selection band.I don’t know if AX supports disable this feature.
Hi Metin,
Thanks for the reply. Yes, absolutely you are right. I want to remove the gird focus and want to place the focus in some other control fields when I am opening the form.
Is there any option for that?
Raman S
