In a “Tabular Form” I need to add a field from a related table. I believe I need to add a “Text Box” then set the “TableRelation” property. Then I would need to tell the “SourceExp” property to look at the required field. It is the exact syntax for the “TableRelation” property and the “SourceExp” properties that I am missing. Any help appreciated. Thank you. Garry
Hi.
If you look at form 46 (Sales Order Subform), this should give you the answer.
Hope this helps
Thank you
