Dear All, I want to integrate mobile with Navision . If any one have PDF regarding that please send me the link of if any one have exp that how to do it please let me know . Thanks
Did you check this http://dynamicsuser.net/forums/p/42265/215440.aspx
hi mohana
Thats not give any info regarding that.
If u hv any PDF regarding that please send me the link…
Devesh
Note this point from the above link
There used to be a mobile solution from Microsoft, but it was discontinued. You would have to find a NAV Partner that does one as an add-on or build one yourself. It can definitely be done.
hiii
How to create add on or how i build do u hv any doc regarding
thanks
Press F1 and in there go to Business Notification → Integrating Microsoft Dynamics NAV Classic with Microsoft Dynamics Mobile.
Hope this would help.
NAV is just like any other SQL database and it’s Web Services work just like any other Web Services. You don’t need documents for connecting specifically to NAV, you just need a generic document. Google should be fine for that.
