Iam having 2 servers for installing Dynamics AX 2009 server.
What is the best way to distribute AOS,Database, Application Files in these servers.
Please let me know each sever should contain what and how to distribute.
Regards
Hari Krishna
Regards
Hari Krishna
Hello,
Typically database (SQL server) is installed in a separate server.
AOS and application are installed in separate server.
For information like installation guide lines, system requirements etc please refer to Ax 2009 installation guide - http://www.microsoft.com/downloads/details.aspx?FamilyId=4B681C44-D944-4B3F-B846-1E2A025569FD&displaylang=en
Are you using SAN Box to store the files.
IF yes then you should have then Performance Point of View require
one Domain Controller (ADS configuration done here)
One Application Server
and Database Should store on San BOX with Data and Log file stored on different logical drive using RAID 1+0 configuration.
Cheers,
Amol
