Reg. Fixing of enum value
Hi Pioneers,
When I select any enum value, it should get freezed at the same time…and after selection, the user shouldnot have authority to change the enum value in that field…kindly suggest me the code
probably allowEdit property on table level is set as ‘NO’ and AllowEditOnCreate is ‘YES’. changing the allowedit property from NO to YES would serve your purpose.
