I have two forms, lets call them FormA and FormB. Both use the same table as their data source. FormB is just used to flip a status field. FormA calls FormmB with a menuItemButton.In FormB, you field in some fields, hit ok and that modifies the data in the data source.
I have everything working correctly, but i was wondering if i did the closing proc for FormB correctly. FormB does the following…
I tried that. However, the code in the clicked method would execute completely then display FormB rather than displaying formB, waiting for a return then executing the code to refresh the dataSource.
