Hello and any help is sincerely appreciated. I am trying to reclassify an asset. I ran the FA Reclass. journal and when I attempt to post the entry using the FA G/L Journal, I get the following error message:
Acquisition Cost must not be negative on 10/31/2013 for Fixed Asset No. = 300041 in Depreciation Book Code = Book
I changed the amount of the entry, such that I was able to post, but I was left with a $0.01 book value and acquisition cost in the Fixed Asset Card. I tried to run the FA G/L journal again to transfer the final penny, but got the same error.
Overall, from an accounting perspective, the difference is immaterial, but I am worried about why this error has happened and I hope it can be solved in case anybody else runs into the error in the future. Also, I cannot delete the asset until the asset is disposed. I haven’t tried a disposal entry for the last penny, so I don’t know if the error would keep reoccurring.
Any insights would be super helpful.
I have attached screen shots.
Hello my Dynamic friends [;)]
I have solved my problem!! However, the solution actually came from Waleed Awny from a different forum website (see link at the bottom).
Here is what happened. Whoever originally imported the data to NAV imported with a rounded number. Therefore, even though my balance appears to be $0.01, in the FA Ledger entry table, the value was actually like .009999999999 or something (rounded off). Therefore, when I try to credit acquisition cost for $0.01, it triggers the error message.
Here is the solution:
- Open the Microsoft Dynamics NAV development environment program.
- Click Ctrl + F (or click the edit drop-down menu and select find).
- Type “FA Ledger Entry” and select the line and click run to open your FA Ledger Entry page.
- Find the ledger entry that needs to be changed (in my case, the original acquisition cost for fixed asset 300041).
- Delete the values in the following columns and retype the values again to the nearest penny ($0.01): Amount, Debit Amount, Amount (LCY).
- Click OK
- Go to the FA G/L Journal and click refresh, and post the transaction.
- In the future, when importing data from Excel, be careful that the values are rounded when importing to FA Journal. Apparently, since the FA Journal does not have G/L integration, there doesn’t appear to be any setup option to round values in the FA Journal.
Here is the link to where I found the solution. This solution should work with any error messages about rounding amounts.
http://community.dynamics.com/nav/f/34/t/10718.aspx
Cheers!
Screenshots Error Solution.pdf (463 KB)
