hello everyone,
I need to convert float (real) to string, the function needs as a parameter how many number after the smi-column, do you have any ideas?
Thank you
hello everyone,
Thank you
Hi widad,
this code will help you …
str a;
int b;
b = real2int(24.23);
a = int2str(b);
info(a);
use the function as:
num2Str( real number, int character, int decimals, int separator1, int separator2);
for more information refer to
hello everyone,
it seems that you didn’t undestand the issue, i need to convert real to string without knowing the number of decimals after the coma, to do this dynamically, here is a solution:
System.Double netDouble;
anytype r1 = 1.125;
str s1;
netDouble = Global::real2double(r1);
s1 = netDouble.ToString();
info(strFmt("%1",s1));
best regards
