Master data tables (like Customer, Vendor, Item) in general have a field called Last Date Modified which typically contains the system date at the point in time when the user has changed the record.
Date fields on Ledger Entry tables (like G/L Entry, Cust. Ledger Entry, Value Entry), like Posting Date, Document Date, …, typically are populated based on the work date at tha point in time
Register tables (like G/L Register, Resource Register, Item Register) tyoically have a field called Creation Date holding a date based on system date; from register tables you can ‘reconstruct’ on what real date (i.e. system date) ledger entries have been created.
That’s it in a nutshell.
Regarding the Change Log: it depends on the setup of the Change Log what will/has been logged. If you want to be able to reconstruct which user at what point has been inserting/modifying/deleting data in any table you have to setup the change log functionality to do that.
But DO NOT EVEN CONSIDER as this will give a tremendous overhead on data creation/modification degrading performance (including an unwanted multiplication of data). Youalso should ask yourself (our your customer?) why you really would like to know this and if it is really relevant.
