Hi
thanks for replying , appreciated
a while ago I was animating the program to see what it was doing and entered a value into the inventdimid or inventlocationid ( can’t exactly remember now)
since then it has kept that value and only products that have a inventdimid equal to this appear on the item form
when I animate the program the classs
InventDimId inventDimIdBlank()
if (!inventDimIdBlank || dataAreaIdDimBlank != curext())
inventDimIdBlank = InventDim::findOrCreateBlank(false).InventDimId;
dataAreaIdDimBlank = curext();
return inventDimIdBlank;
returns with a value
NAME:
inventDimIdBlank
VALUE:
11760_060
TYPE:
str 20
but where has it got this value from is my real question as I cannot find where to change it - I think it is normally set to “Axapta” -
( if you open the item form from inventory and right click and select set up and then query tab - under InventItemLocation and Ranges the default in the VPC is inventDimId==Axapta )
The whoe class content is below - and the dataareaid is populted wih “dmo” which it must know from the company I am logged into , so where does it get the other values from ?
NAME:
this
VALUE:
new
TYPE:
InventDimGlobal
NAME:
dataAreaIdDimBlank
VALUE:
dmo
TYPE:
str 3
NAME:
dimSearchBase
VALUE:
new
TYPE:
InventDimSearchBase
NAME:
fields
VALUE:
<size = 8>
TYPE:
container
NAME:
fields_read
VALUE:
true
TYPE:
boolean
NAME:
fieldsEnabled
VALUE:
<size = 8>
TYPE:
container
NAME:
fieldsEnabled_read
VALUE:
true
TYPE:
boolean
NAME:
fieldsEnabledName
VALUE:
<size = 0>
TYPE:
container
NAME:
fieldsEnabledName_read
VALUE:
false
TYPE:
boolean
NAME:
fieldsName
VALUE:
<size = 8>
TYPE:
container
NAME:
fieldsName_read
VALUE:
true
TYPE:
boolean
NAME:
handleListForm
VALUE:
{65123, 65124, 65125, 65126, 65128, 65130, 65132, 65469, 65477, 65478, 65480, 65481, 65482, 65485, 65487}
TYPE:
Set
NAME:
handleListReport
VALUE:
null
TYPE:
Set
NAME:
inventDimIdBlank
VALUE:
11760_060
TYPE:
str 20
NAME:
inventDimParmInitAllCovDim
VALUE:
<recid = 0>
TYPE:
InventDimParm
NAME:
inventDimParmInitAllCovDim_read
VALUE:
false
TYPE:
boolean
NAME:
inventDimParmInitAllItemDim
VALUE:
<recid = 0>
TYPE:
InventDimParm
NAME:
inventDimParmInitAllItemDim_read
VALUE:
true
TYPE:
boolean
NAME:
inventDimParmInitAllPriceDiscDim
VALUE:
<recid = 0>
TYPE:
InventDimParm
NAME:
inventDimParmInitAllPriceDiscDim_read
VALUE:
false
TYPE:
boolean
NAME:
inventDimParmInitAllstorageDim
VALUE:
<recid = 0>
TYPE:
InventDimParm
NAME:
inventDimParmInitAllstorageDim_read
VALUE:
false
TYPE:
boolean
NAME:
inventDimSetupGridList
VALUE:
null
TYPE:
List
NAME:
inventDimSetupGridList_read
VALUE:
false
TYPE:
boolean
NAME:
itemDimFieldsEnabled
VALUE:
<size = 0>
TYPE:
container
NAME:
itemDimFieldsEnabled_read
VALUE:
false
TYPE:
boolean
NAME:
itemDimFieldsEnabledName
VALUE:
<size = 0>
TYPE:
container
NAME:
itemDimFieldsEnabledName_read
VALUE:
false
TYPE:
boolean
NAME:
parmFields
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFields_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsEnabled
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsEnabled_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsEnabledName
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsEnabledName_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsLarge
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsLarge_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsLargeEnabled
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsLargeEnabled_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsLargeEnabledName
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsLargeEnabledName_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsLargeName
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsLargeName_read
VALUE:
false
TYPE:
boolean
NAME:
parmFieldsName
VALUE:
<size = 0>
TYPE:
container
NAME:
parmFieldsName_read
VALUE:
false
TYPE:
boolean
NAME:
storageDimFieldsEnabled
VALUE:
<size = 0>
TYPE:
container
NAME:
storageDimFieldsEnabled_read
VALUE:
false
TYPE:
boolean
NAME:
storageDimFieldsEnabledName
VALUE:
<size = 0>
TYPE:
container
NAME:
storageDimFieldsEnabledName_read
VALUE:
false
TYPE:
boolean
NAME:
systemHasMultipleItemDim
VALUE:
true
TYPE:
boolean
NAME:
systemHasMultipleItemDim_read
VALUE:
true
TYPE:
boolean
Many thanks
