When we estimate the batch order for subcontracting product then we get line in Production >subcontracting work.
In one of the environment I get it only afer I operation schedule the batch order …where is the setting due which this difference is there?
There is not one as standard, always after estimation, unless there is no estimation requirement in the status setup of course.
The status setup are same in both environment.
Is there any other setup?
No, and the data should not matter - any modifications?
You will need to get a developer to look at the code, as far as I am aware this is automated at the movement of an order from “Created” and is a coded setting so always happens.
Now the problem has solved automatically…I have not done any change in settings.
STRANGE!!
