Question about List in AX
Hi everyone,
I have the following code:
Solution (1):
1-1: List purchRFQVendLinkList = new List( tableNum( PurchRFQVendLink ) );
1-2: while select purchRFQVendLinkLocal
where purchRFQVendLinkLocal.RFQCaseId == purchRFQCaseTableLocal.RFQCaseId
purchRFQVendLinkList.addEnd(purchRFQVendLinkLocal);
Then, I have an error dialog which says the ‘The type is not as expected’;
If I change to
Solution (2):
2-1: List purchRFQVendLinkList = new List(Types::String);
2-2: while select VendAccount from purchRFQVendLinkLocal
purchRFQVendLinkList.addEnd(purchRFQVendLinkLocal.VendAccount);
It works fine.
So, I am wondering why solution (1) cannot work, the declaration of 1-1 is not right? I know “List” in AX can contain any type of X++ object, right? It’s a little weird to me now.
Thank you,
Kwen
List’s constructor expects a value from Types enumeration, e.g. Types::Record.
You call it as new List(tableNum(…)) - tableNum() returns an int value, which is compatible with the enum parameter (enum values are just named numbers). so you don’t any compilation error, but the code makes no sense.
I changed to Types::Record, and solution (1) started to work. Learned something good, thank you, Martin~
