where can I find information about QueryBuildDataSource methods.
I’m interested in exaples, explanation what do those methods.
Where i can find it??
The class and its methods are documented here: QueryBuildDataSource on MSDN. You can find many examples in standard AX - use cross references for finding them.
this is a lookup with QueryBuildDataSource .Lookup at this maybe its help you.
public void lookup()
Query query = new Query();
QueryBuildDataSource qbds;
QueryBuildDataSource QbdsJoin;
// Instantiate sysTableLookup object using table which will provide the visible fields
SysTableLookup sysTableLookup = sysTableLookup::newParameters(tableNum(TableName), this);
// Create the query.
qbds= query.addDataSource(tableNum(TableName));
qbds.addRange(fieldNum(TableName, FieldName)).value(‘Value’);
//Join Table
QbdsJoin= qbds.addDataSource(tableNum(TableName2));
QbdsJoin.relations(true);
QbdsJoin.joinMode(JoinMode::ExistsJoin);
QbdsJoin.addRange(fieldNum(TableName2, Fieldname)).value(‘Value’);
// Set the query to be used by the lookup form
sysTableLookup.parmQuery(query);
// Specify the fields to show in the form.
sysTableLookup.addLookupfield(fieldNum(TableName, FiledName));
sysTableLookup.addLookupfield(fieldId2Ext(fieldNum(TableName, Dimension), 1));
// Perform the lookup
sysTableLookup.performFormLookup();
