In Dynamics AX 2009, when I create a new Quarantine order, all dimensions are copied except the color dimension
it’s a dynamics ax bug ?
how can I fix this ?
Debug and check where the dimensions are getting filled and compare that code using AX compare tool to check if the dimension initialization code is custom code or standard code .
To fix the this issue, just initialize the color dimensions with your desired dimension where the other dimensions are getting initialized
