Is there any suitable QC-Addon for AXAPTA available from any of the Indial Microsoft Business Solution Partners?
Thanks and Regards.
Vijay
Thanks and Regards.
Vijay
What is wrong with the quarantine management written into Axapta?
WIth AXAPTA Quaratine Management I can not:
-Define the Paramters(such as Length, Width, Thickness, Ph etc) that need to be tested.
-Define any Sampling Plan.
-Define Inspecting Departmetn or Personnel.
-Capture the Test Results.
This are some of the activties which I found could not be captured using the Quarantie Management available in AXAPTA.
Regards.
Vijay
Yep you will need an add-on then. I believe there is an official add-on catalogue - have you looked at this?
HOB in denmark has made one, http://www.hob.dk/DA/TopMenu/Brancher/Produktion.htm the site is in danish but the contact details are in the buttom
