HI all,
How can you setup an escalaton where after x days if no answer from the approver, a reminder should be sent again to the approver.
thanks
HI all,
thanks
You can escalate to another approver. If you want to keep it with the same approver, then it’s not an escalation - you’re looking for a kind of reminder.
Exact Martin. So how do you setup that reminder Thanks .[:)]
The task is still assigned to user, so he/she can see notification in AX etc. I would suggest you teach users not to ignore work assigned to them.
But if you want, you can periodically look at assigned tasks and send e-mails with remainders.
thanks for the suggestion. But if user works with AX portal, what is the solution
What’s the difference? I would say that everything still applies.
