Any can tell me why Purchase order is showing different behavior based on the workflow which is used.
I can edit an approved/confirmed Purchase order which is released from Purchase Requisition. But I am unable to edit an approved/confirmed Purchase Order which is not released from Purchase Requisition (directly created PO) .
Yes, ‘Activate change management’ is enabled. But my question is why Purchase order is showing different behavior based on the workflows used.
I can edit the purchase order (after all the review/approvals) if I create a purchase requisition and release to Purchase order (after purchase requisition workflow review/approvals)
But I can’t edit if I create a purchase order directly (without purchase requisition) .
There must be some customization around if you are trying to edit the PO before approval, i.e., in the status Draft.
The reason I had asked you about ‘Activate Change Management’ is because if it is activated and PO workflow is defined & active, the user will not be allowed to change the PO after approval and Request change form should be used there after for any changes to PO.
