Has anyone else had an issue with the prompt quantity field on the picking list and packing slip defaulting? I understand that this should be a user set up issue and even after clearing usage data, the quantity field is still grayed out. It is as if this has been set on a company level. Is that possible? How does one change that?
The ‘prompt quantity field when posting document’ is checked in the A/R parameters and the procurement & sourcing parameters.
Thanks for your help.
Donna
