Project Invoice Report
Hi
I have a requirement to changing the design of a project invoice report on company specific .
module name : project management & accounting
Path :Project management and accounting/Common/Projects/Project contracts/Invoice journals/print/selected
visual studio projects name : ProjInvoiceReport
ssrs report : ProjInvoice
in the designs part i created another design for suppose CustomizedReport.
also I created Output menu for that but how to call that report in controller class .
deployed ,built , add to AOT successfully .
But in the controller class where I have to change the coding for that when the selected Button will clicked it only call my Customized report rather than base report .
If is there any way please mention .
Kindly help on this .
Sumit
Hi
I am Using Ax 2012 CU7 R2
Kindly Help me .
Sumit
ProjInvoiceController normally chooses the design in main() method according to the configuration of print management. You may want to somehow extend this logic.
Hi Martin
I am glad your valuable responds , Would u Kindly mention me where exactly in that main() I will call my Report or Output menu item .
My point is that the logic is already there.
ProjInvoiceController::main() contains, among other things, the following statement:
controller.parmReportName(
        PrintMgmtDocType::construct(PrintMgmtDocumentType::ProjectInvoice)
    .getDefaultReportFormat());
And getDefaultReportFormat() selects the design to use. For example:
if (SysCountryRegionCode::isLegalEntityInCountryRegion([#isoLT]))
	return ssrsReportStr(ProjInvoice, ReportLT);
if (SysCountryRegionCode::isLegalEntityInCountryRegion([#isoHU]))
	return ssrsReportStr(ProjInvoice, ReportHU);
