Can i know how to estimate the project and how to link with actual project ,how to post estimation hours,items and what are the setups required for this process
Hi Kola,
The estimate project is vast functionality and is related to advance project management. All your points can’t be answered here considering the depth of functionality.
However, i will put down some basic points related to estimate projects.
Estimate projects are typically used with fixed price project although it can be used with internal project also.
Whenever a FP project is created you can create a estimate project simultaneously. Project setup can vary and hence its related setup.
Estimates project are mainly used to post estimates for a project when duration is long. After the project is estimated, then only it can be eliminated which is like project closure.
Pranav…
