Does anyone have an idea how to programmatically import an existing XPO file?
Hi Daim, The form from which one can manually import is SysImportDialog. In that form, have a look at Import method under form methods. Hope this gives you some idea. But I feel manual importing gives you more control over objects, label, language that you import. BTW, is there any particular reason you want to import XPO programmatically? Regards, Harish Mohanbabu
