production orders status
Dears ,
I have an issue in the production module which is as below :
today I 've opened the ax2012 -----> all production orders then I found that the status of all the production orders have been changed from report as finished to the status started I do not know what’s is the problem ,
looking for some help on such situation .
regards
So someone went in and changed the status - what they will have done is gone to one order and chosen to reset, then decided to press the select button and cleared the single order filter, pressed OK and then all orders would have been returned, they then pressed OK again.
yes this is what happened exactly ,
but i need to revers this action cause all production orders are finished .
You cannot reverse it, now you need to set each one back to RAF, and you will need to do this individually and re-report all posted journals etc.
