i have problem in production order, whenever I post Report as finished items has not been completely Released what can i do pls help…
Version? Process? Settings on RAF? Consumption flushing? Start parameters?
I would guess you are creating a journal at some point for the pick and either posting it or not and the picking complete flag is not set on each line (end picking or something).
Try checking “Accept error” on the Report as Finished when posting. But, afterwards I would verify that all Production line, Route, and Indirect transactions posted properly. Need more detail as to your parameter settings.
Hi Michelle, the Accept Error parameter only allows to RAF a different quantity than the one started, more or less, but just that.
Accept error also allows you to RAF if say you have 4 operations but only posted Route card journals for 2 of them and want the remaining to backflush.
