I have Finish the Production of a BOM, there are 20 Qty of it, Now i want to Assign Serial Number to all the QTY, How it is Possible.
BOM has Serian Number Dimension Active and Also I have Tried to Registered it From Prouduction–>Inventory–>Registration but it is not Working. the Create Serial Number button is not active.
Also While Spliting…How to Split 20 Qty, to 1 in One Shot…as While i do spliting it ask for Split Qty when i Put 19 then It Creates 19 + 1 Qyt…and while Puting 1then it Creates 1 + 19 Qty…
Please Suggest the Idea on the Same.
The Above Question is Shorted Out as By Mistake the Serial Number was De-activated By user as it was new item and there was no transaction pending on it.
To have a Serial Number for an item, activate the Serial Number Dimension in the Inventory Dimensions form and attach the same Dimension group to an item.
Also Create a Serial Number Group, and create a Number sequence for that group, and select the following check boxes:
Number sequence No.
Only for Inventory Transactions
On Physical Update
Per Qty = 1 , if you want to have individual Serial Number for each item.
While doing Report as Finished of a Production order, the Report as Finished Quantity (i.e.) Good Quantity will have serial number attached with it based on the above settings.
D. Praveen Kumar
Praveenji,
Thanks For the Reply… The Problem Was Already Shorted out…But thanks For the Solution…You Have Already Helped me on Serial Number Things.
Thanks a Lot…
