Production order - material consumption
I create a production order, and I can start the production order, and AX post the picking list journal and route card journal automatically. However the status still stay as “Started”, and the remain status is “material consumption”. If I report it as finished, it will pop up an error as below:
Either the picking list is not posted or the posted picking list does not contain these items.
Additionally on your RAF parameters you maybe posting the picking list again.
A simple way to test this is to set the picking list to ALWAYS at start and then complete it, the message should go away (set RAF to None), because everything is consumed as expected.
