Production Cycle
Hi All
I have to start the production module in Ax 2009,And my process is as follow:
1- I HAVE A PRODUCTION OF BAKERY PRODUCTS.
2- ONE SITE AND 7 PRODUCTION AREAS FOR WHOM I HAVE TO MAINTAIN THE STOCK ISSUE FOR PRODUCTION SECTION WISE. MEAN FROM ONE SITE AND ONE WAREHOUSE I WILL ISSUE THE GOODS TO ALL 7 SECTION. aND SECTION WISE I HAVE TO TRACK TO WHICH SECTION HOW MUCH RAW MATERIAL IS BEEN ISSUED.
FOR THAT I CREATED THE ONE SITE AND 7 WAREHOUSE FOR EACH SECTION.
3- I HAVE TRIED WITH DEFINING THE WAREHOUSE AT BOM LINE LEVEL BUT IT NOT WORK OUT.FOR EXAMPLE IN BOM CREATION OF CAKE I DEFINE THE SITE SAY S1 IN BOM AND IN BOM LINE I HAVE BUT W1(SECTION 1 FOR CAKE) BUT IN THE ITEM ON HAND IT IS SHOWING THE -VE QUANTITY.
CAN ANYONE ADVISE ME HW CAN I MAP THIS PROCESS IN AXAPTA
THANKS
Issued or transferred? To issue it from a warehouse you need to transfer it there. If you have warehouse at the BOM line it will work, it will create demand on that warehouse that you need to supply. Alternatively you could try work centre consumption and one BOM aligned with routing and production units.
The item on hand will show negative, it is the requirement, you need to move the stock required at the warehouse which depends upon your item coverage group.
In essence the details you have given are not enough, first you have made an assumption of 1 site and 7 warehouses which drive you down a route. So if you are intent on this you need to set the replenishment methods up from your main stores to your 7 sections. You need to manage this and move stock to track movement and issue.
Thanks Adam for replying.Actually i am new in AX and first time working on Production module.
Actually my scenario is like:
1- my purchase(Raw material) come in SITE1 and warehouse W1.I just have one site SITE1 and one warehouse W1 from where the raw material will be issued to the different sections of the factory.
2- I have 7 sections(each different name) to which i have to issue the raw material from site SITE1 and warehouse W1.
3-I want to track section wise like how much and what material i have issue to particular section in particular span of time.
and what is the use of defining site in BOM and warehouse in BOM line.
please advise me i am very confused.
thanks
To chieve this you need to look at linking your BOM items to the routing, but this is not something you can just pick up, you need help, someone to sit with you and explain how it works.
The site and BOM on the line define where stock will be flushed/consumed from.
Can u explian me the difference in Default, , and
