Production BOM and machine center
Dear All, I would like to ask your help to explain me about the use of these following fields and have the fields implemented now and in what manufacturing companies : a. Position/Position 2/Position 3 fields in production BOM b. Minimum and maximum process time in machine card I am thankful for your attention and answer beforehand. rgds, Johnson
The position field generally relates to a point on the BOM drawing, these are called reference designators in other oindustries. A good example is electronics where the position field references where it is on the drawing and where it needs to go in the BOM assembly. You of course can use them for whatever purpose you want. The processing times are reference only for lags in the commencement of work. I do not believe Navision uses these in any capacity planning.
