I am new to ax 2012 and gettingmy head around the master product>product way of doing things.
One of the things I am looking for is where is the “version” field to put in what version of the product you are working with. Is that in a different place?
Thanks!
hi Allen,
On AX 2012 Client, right hand top corner, you will find the help icon. Click on help icon (alternatively press ALT + H), go to “About MIcrosoft Dynamics AX”. You will find the version information (Kernel Version, Application Version).
Also, you can map build version to Ax releases at following site:
http://blogs.msdn.com/b/emeadaxsupport/archive/2009/07/01/overview-ax-kernel-build-numbers.aspx
Hope this helps.
Gaurav
I didn’t ask the correct question.
the question should have read: If I want to know the latest revision of a part in AX, where would I find that? If that in the Product Information Management section?
Allen
