Hi ,
What is the difference between product dimensions vs product variants in AX 2012 and explain with an example ?
( product variant in AX 2012 is nothing but an “Item dimension combination” in AX2009.) Am i right ?
Hi ,
You are right lally, product variant is item dimension combination in AX2009. Also, product dimension is same as item dimension in AX2009.
A product dimension could be as follows:
Size - Small, Medium, Large
Colour, Black, White.
A product Variant would be
Small - Black
Medium - Black
Medium -White
Large - White
For the missing variants you would not be able to enter the combination, even though Black is a valid product dimension and Large is also a valid product dimension it is not a valid variant.
Thanks Santosh & Adam ,
In AX 2009 there is an option to create the Product variants automatically , what about in AX 2012 and let me know the path of the option .
Thanks in advance.
Yes there is.
You have the auto-create combination check box on the item or the wizard to create them from the combination view. The same functionality exists in AX2012.
Path: Released product details>General-Fast tab>Product variants field group> “Generate variants automatically”
