Processing XML in NAV2018
Hi everyone,
I’ve integrated NAV2018 with a webService from a delivery service. Everything works perfect, but knwo I need to receive the status of a shipment from another webService. The XML I receive is like this:
As you can see, inside the “CONSULTA” node, i have a list of 3 (in this case) “ENV_ESTADOS I_ID”. How can I get the last one, and get the value of “V_COD_TIPO_EST” field? I’m using 6224 codeUnit, but I don’t finde the way…
Any tip will be welcome.
Thank you all, hope you all are safe and healthy
you could store values in a table and get what values you want from the table
Thanks IMRAM, The problem was to process the atrivbutes, but finally found the way
