I am trying to install the RoleTailoredClient with the following string silent at some clients:
X:\Navision.ins\CD_2009R2_YAVEON\setup.exe /quiet /config x:\Navision.ins\CD_2009R2_YAVEON\RoleTailoredClient\config.xml
The issue is that the setup will not start on some of these systems. …also without extension (/quit…).
There is nothing to find in the event log and the setup log is empty:
=== Logging started: 2011/10/10 17:02:48 ===
Executable: x:\Navision.ins\CD_2009R2_YAVEON\setup.exe v6.0.32012.0
Computer : PC_BEK
— logging level: standard —
=== Logging stopped: 2011/10/10 17:02:48 ===
The setup works fine on some systems and I tried the following things on system with this issue:
- Closed all applications
- started XP with the diagnostic start
- stopped AV etc.
- started the setup from a local drive (C:)
- downloaded and ISO from technet and started the setup from DVD
Other setups with setup.exe works fine…
Client configuration:
- Windows XP SP3
- Windows Updates installed every updates
- 58GB free disk space
- 2GB RAM - 1,4GB free
Did I miss any requirements, which I did not recognize and which are checked at the start?
I can start and install the “Microsoft Dynamics NAV RoleTailored Client.msi” without any problems… but I need the silent installation.
I am thankful for any assistance!
Thanks and viele Grüße
Christian
