Hi!
I have a problem with an xml that I like import in NAV 2009 with XMLPorts.
My XML is:
<env:Envelope xmlns:env="">schemas.xmlsoap.org/…/">
env:Header</env:Header>
env:Body
<ns0:getOperacionesResponse xmlns:ns0="">http://gasoil.interna/">
http://gasoil.interna/">](http://gasoil.interna/)
60.0
0
1
2986
204479
9999
8899788532
0001-01-01T00:00:00+01:00
2010-08-31T23:59:59+02:00
4440
XX5BCB
0.0
19
Gasoleo C
I had defined an XMLport with this structure (following this link: www.mibuso.com/…/viewtopic.php
In my XMLPort
OnPreXMLport()
NS1 := NSpace1;
NS2 := NSpace2;
NS3 := NSpace3;
Globals:
My codeunit for import the XML.
importGasoil()
file.TEXTMODE(TRUE);
file.WRITEMODE(FALSE);
file.OPEN(‘c:\FacturacionGasoil.xml’);
file.CREATEINSTREAM(inStream);
XMLPORT.IMPORT(XMLPORT::MyXMLPortGasoil,inStream);
I receipt a lot errors when I launch my codeunit for import this XML the first is " element doesn´t exists in description object".
Anybody had the same problem and found the solution?.
Thanks in advance!!
Ana
