Hi all!
We have a problem with Sum aggregate function.
For example:
The value in the table is: 123,45
It returns: 1234,5
Someone have the same problem?
Thanks for the replies.
Hi all!
For example:
It returns: 1234,5
It’s much more likely that the problem is in your code than that you’ve just found a serious bug in AX or SQL Server.
Can you show us what exactly you did?
This is my code:
query = new Query();
qbds = query.addDataSource(tableNum(ProjInvoiceJour));
qbds.addSelectionField(fieldNum(ProjInvoiceJour, InvoiceAmount), SelectionField::Sum);
qbds = qbds.addDataSource(tableNum(ProjProposalJour));
qbds.joinMode(JoinMode::InnerJoin);
qbds.addLink(fieldNum(ProjInvoiceJour, ProjInvoiceProjId),fieldNum(ProjProposalJour, ProjInvoiceProjId));
qbds = qbds.addDataSource(tableNum(ProjProposalEmpl));
qbds.addLink(fieldNum(ProjProposalJour, ProposalId),fieldNum(ProjProposalEmpl, ProposalId));
qbds = qbds.addDataSource(tableNum(ProjEmplTrans));
qbds.addLink(fieldNum(ProjProposalEmpl, TransId),fieldNum(ProjEmplTrans, TransId));
qbds.addSelectionField(fieldNum(ProjEmplTrans, ProjId));
qbr = qbds.addRange(fieldNum(ProjEmplTrans, ProjId));
qbr.value(projId);
queryRun = new QueryRun(query);
while (queryRun.next())
//info(queryRun
jour = queryRun.get(tableNum(ProjInvoiceJour));
print jour.InvoiceAmount;
pause;
This is query query string (got by calling query.dataSourceNo(1).toString()):
SELECT SUM(InvoiceAmount) FROM ProjInvoiceJour(ProjInvoiceJour_1)
JOIN * FROM ProjProposalJour(ProjProposalJour_1)
ON ProjInvoiceJour.ProjInvoiceProjId = ProjProposalJour.ProjInvoiceProjId
JOIN * FROM ProjProposalEmpl(ProjProposalEmpl_1)
ON ProjProposalJour.ProposalId = ProjProposalEmpl.ProposalId
JOIN ProjId FROM ProjEmplTrans(ProjEmplTrans_1)
ON ProjProposalEmpl.TransId = ProjEmplTrans.TransId
AND ((ProjId = N'Some project ID'))
Is it what you want? Didn’t you want, for example, the filter ProjInvoiceJour by project ID?
Unfortunately I don’t know data in your database, so I can’t tell what the query returns.
I want to sum all the invoice amount for each project.
That’s not what your query does, it take into account only invoices created from proposal, with at least one employee transaction and just for a single project.
