hello everyone I have a problem with receiving a transfer order showing the below message:
Function InventTrans.inventMovement has been used incorrectly.
I tried to receive all shipment except line number 5 but no change
please help
please help
Error message when you invoice an intercompany sales order: “Function InventTrans.inventMovement has been used incorrectly” Consider the following scenario. You post a packing slip on an intercompany sales order. Then, you reverse the posted packing slip. Next, you invoice the intercompany sales order. In this scenario, you receive the following error message: Function InventTrans.inventMovement has been used incorrectly. This problem occurs if the Unit price equal to cost price check box was selected in the Intercompany action policy dialog box when you set up the sales order endpoint. The Intrastat output file displays data in an incorrect format After you use the Output feature to generate a disk for an Italian Intrastat transaction in an Intrastat form, the Intrastat output file displays lowercase letters instead of uppercase letters. However, alphanumeric characters must be output by using uppercase letters. Hotfix rollup information A supported hotfix rollup is now available from Microsoft. The hotfix rollup corrects the problem that is described in this article. Apply the hotfix rollup only to systems that are experiencing this specific problem. To resolve this problem immediately, contact your Microsoft Dynamics partner or Technical Support for Microsoft Dynamics and related products to obtain the hotfix rollup. If you have access to online assisted support you can log on to the Microsoft Dynamics site and create a new support request. To do this, visit the following Microsoft Web site: https://mbs.microsoft.com/support/newstart.aspxYou can also contact Technical Support for Microsoft Dynamics and related products by telephone. To do this, visit the following Microsoft Web site: Partners https://mbs.microsoft.com/partnersource/resources/support/supportinformation/Global+Support+Contacts Customers https://mbs.microsoft.com/customersource/support/information/SupportInformation/global_support_contacts_eng.htm In special cases, charges that are ordinarily incurred for support calls may be canceled if a Technical Support Professional for Microsoft Dynamics and related products determines that a specific update will resolve your problem. The usual support costs will apply to any additional support questions and issues that do not qualify for the specific update in question. This hotfix rollup is scheduled to be included with Microsoft Dynamics AX 4.0 Service Pack 3. If you are a customer and if you do not have a Premier Support Agreement with Microsoft, you must contact your partner to obtain this hotfix. Installation information For more information about how to install this hotfix rollup, click the following article number to view the article in the Microsoft Knowledge Base: 893082 How to install a Microsoft Dynamics AX hotfix Prerequisites You must have Microsoft Dynamics AX 4.0 Service Pack 2 installed to apply this hotfix rollup. Restart requirement please check this http://support.microsoft.com/kb/951724 and please mention your ax version
I am facing error “Function InventTrans.inventMovement has been used incorrectly” while receiving Transfer order. But i am able to receive TO without troubled item#18. I set Receive Now qty of item#18 to ‘0’ and received the TO. We also have customization with Transfer Order process. Can anyone guide.
Your advise will be highly appreciated.
Have you applied the discussed hotfix in the post?
I see mentioned hotfixes are older, we are using AX2012 R2 CU1 version. Did you recommend to apply hotfixes, reason?
Now I know your version it is different - have you looked for a hotfix from R2 CU1?
Thanks Adam,
I have checked hotfix KB951724 is applied to Intercompany Sales order and not cover Transfer order, see below text copied from Hotfix rollup article 951724 (Dynamics AX 4.0 Service Pack 2). I did not find similar hotfix for AX 6.0, shall I try to apply the hotfix or ticket Microsoft, please suggest.
QUOTE:
Error message when you invoice an intercompany sales order: “Function InventTrans.inventMovement has been used incorrectly” | \Classes\SalesLineType\InterCompanyCalcSalesPrice |
UNQUOTE:
So assuming there is no report of your issue in your version the next step is to get a developer to debug it tell you exactly what the issue is.
The subject error stopped appearing on Transfer order, and don’t know if/when it will appear again. But we have started facing error “Function InventTrans.inventMovement has been used incorrectly” on Retail statement posting. I am not able to guess this strange behavior but we have assigned a developer to diagnose reason of error. I will share our findings.
