This won’t compile. Keep getting an error message on the Yes. JobComplete is an Option field with No, Yes the only 2 values on it.
IF (JobComplete = JobComplete::Yes) AND
(JobCompleteDate = 0D) THEN BEGIN
JobCompleteDate:=WORKDATE;
END;
This works but I hate to hard code the 1 in there:
IF (JobComplete=1) AND
END;
Thanks in advance,
Greg
Attached is the error message:
Your option value is " Yes", with a space before the Yes part. Don’t put spaces between option values. Unless of course that is your intention, and you need to code it like this:
IF (JobComplete = JobComplete::" Yes") AND
The parentheses are not necessary in this case, although I like them there.
So, instead of the optionstring “No, Yes”, change it to “No,Yes” without a space after the comma, and your original code should compile just fine.
no problem, it’s an easy mistake to make (I have regularly made it myself) [:)]
