problem with form refresh ((.reread()) no refresh refresh refresh
Hi friends
I have problem with form refresh ((.reread())
In form have many data select from many table
when I compile run the form the next and provide button work
I have button have update function
After update I need to close the form to refresh data
Can write to me the function or which methods call to refresh inside button
Note that I used it to function all my data sources (all my table).reread()
BankAccountTable.reread();
CHECKISSUE.reread();
BASICDATA.reread();
CHECKISSUE_DETAIL.reread();
CHECK_NUMBER_TABLE.reread();
Use as for example BankAccountTable_ds.reserach()
Naresh kolli
thanks for your help
after use reserach give u 1Fr row and refresh but u can’t print other u print only 1FR row
i don’t now if have function after close the reprt form go to the form or refresh form
Vanya Kashperuk wrote an excellent tutorial on the correct usage…this will get you going.
http://kashperuk.blogspot.com/2010/03/tutorial-reread-refresh-research.html
