Hello Experts,
I am using Nav 2009 SP1. I used shell functions to execute a batch file to extract some archived files (some .txt files).
I used 7 zip command line in windows server 2003 with 32 bit and everything was ok.
Now we are testing in Windows Server 2008 64 bit. When I execute manually command line the extract is ok.
When I execute batch file with shell function from Nav I have this error
“7z is not recognized as an internal or external command operable program or batch file”.
Where is the problem?
Does anyone has the same problem?
Best Regards.
