Hi everyone,
I’m finding an issue with the upgrade and migration of NAV. In the old server, I was running a self developed WebApp, that was consuming different webServices from NAV2013 without any problem. The WebApp is develoepd in C#.
Now, I’ve migrated NAV to a new server, and upgraded to NAV2018. In the WebApp, I’ve changed the references to the webService in the new server. I’m connecting to the app forms without any problem, but when it needs to use any of the webServices, I found this error in the Event Viewer:
Event code: 3005
Event message: Excepción no controlada.
Event time: 17/04/2018 9:33:56
Event time (UTC): 17/04/2018 7:33:56
Event ID: 1377ba09b69b4676912727c7c2a74b71
Event sequence: 12
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/2/ROOT/Picking-1-131684240033263190
Trust level: Full
Application Virtual Path: /Picking
Application Path: C:\Websites\Picking\
Machine name: SRV-DC01
Process information:
Process ID: 4724
Process name: w3wp.exe
Account name: IIS APPPOOL\Website
Exception information:
Exception type: WebException
Exception message: Error de la solicitud con el código de estado HTTP 401: Unauthorized.
en System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
en System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
en WebService.PDAMgt.ExistePicking(String numPicking)
en Picking.Entrada.txtCodigo_TextChanged(Object sender, EventArgs e)
en System.Web.UI.WebControls.TextBox.OnTextChanged(EventArgs e)
en System.Web.UI.Page.RaiseChangedEvents()
en System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Request information:
Request URL: http://srv-dc01:8090/Picking/Entrada.aspx
Request path: /Picking/Entrada.aspx
User host address: 192.168.2.140
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\Website
Thread information:
Thread ID: 7
Is impersonating: False
Stack trace: en System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
Custom event details:
The access to Nav is navUserPassword.
Any hint with this issue? If any info is needed, I will answer immediately, I’m quite desperate with this…
Thank you all
