Problem opening of Demo Database.
Hi Rajat,
As the message show ‘The database has already been converted by a newer version’, so you need to know which version you has converted the database to (to check this, run Development Environment (the new version), if you can open database with no error message, it’s good to go) . Then just create a new instance (the new version) for the converted database and run it.
