Iam getting error as
" Type must be G/L in purchase line document Type = ‘order’,Document No = ‘10605’,Line No = 0 "
In line i have selected as item and when i select an item it is giving error as the above.
Kindly check type field on the purchase line .If u r selecting Item then it should be ‘Item’.
Amol
it is item only but iam still getting that error
hi
you should select g/l type in that option
where you are selecting item
megha
