I am creating Transfer Order and i have given “From Code” Location and “To Code” Location but When i tried to select In Transit Location which is IN-01 defined as In-transit Location.After Selecting from “Location List” it’s not showing in Transfer Order Form and due to that i am not able to give item no. and quantity in transfer order…
Actually, you cannot see the In-Transit Locations in your Transfer-From and Transfer-To lists! Your TO from should have another field called (In-Transit Code) where you can see and select your in-transit location (those that you maked as Use As In-Transit).
In fact you take your goods from a warehouse location and put in In-Transit (In-Transit Code) and then you will receive the goods from in-transit in the destination warehouse(Transfer-To Code)
What (Transfer Route) does is that, you tell the system that what the default (In-Transit Code) is for the combination of Transfer-from and Transfer-to locations that I choose so system will fill that field automatically and who is the shipping agent and the service contract code for this transition!
