I created a new table “Purchase Requisition” and in that there are two fields which are correlated they Department Code and Department Description those fields are fetching from same table Dimension Value.
I am fetching Value of Department Code field from Dimension Value "Code " only where Dimension = Verticals and Department Code value is fetching properly there is not any problem.
2.But when i tried for fetching for “Department Description” which should be same name of the “Department Code” but its not coming i also tried Flow Field to get this value but Flow filed is displaying value when i close the table or refreshing navision please guide me.
