Problem in Direct Sales Order by Web Service
Hello Friends,
Error:
You may not enter numbers manually. If you want to enter numbers manually, please activate Manual Nos. in No. Series ORDRE1.
The error message is very clear.
what did you try to resolve the error?
Hello Mohana,
I have change setting of order but in manually order
Error: with Web Services
The Sales Header already exists. Identification fields and values: Document Type=‘Order’,No.=‘VM00024’
Error: When Entry in Navision Sales Order
Posting Date is not within your range of allowed posting dates.
in Sales Header Document Type=“Order”,No.=“1055”
Can you help me
thanks
Regarding the error shown in NAV you have to check dates “Allowing posting from”/“Allowing posting to” in General Ledger Setup, VAT Posting Setup and User Setup tables.
For the web service you probably didn’t fire the Sales Header trigger which call No. Series Management codeunit: how did you perform the insert?
Check the allowed dates in General Ledger Setup as well as User Setup also.
