Ok, for the sake of full disclosure, I’m pretty new to AX.
I’m trying to make it through the following walk through:
http://msdn.microsoft.com/en-us/library/cc589855.aspx
I’m at the point where I’m trying to “To configure the endpoint.” In step 4 you select the LedgerJournalService.read. In step 5 you enable it. In step 6 you select Log All, and in step 7 you save the endpoint, accept that for me I get the error:
The class method for the specified action ‘LedgerJournalService.read’ could not be found.
Peering into the code, I find that the point of failure is the following:
dictMethod = new DictMethod(UtilElementType::ClassInstanceMethod, action.ClassId, action.MethodName);
if (!dictMethod.compiledOk())
throw error(strfmt("@SYS117359", actionId));
This code exists in the \Data Dictionary\Tables\AifParameterLookup->getActionMethod.
Debugging, I can see that action.ClassID is 50014, action.MethodName is “read”. For some reason that I can’t determine, dictMethod.compiledOk() returns false. I am, however, able to compile the service class “LedgerJournalService” without error, and in fact, the entire project without error or warning.
