Printing the Table values on Report
Hi All ,
I want to print the customer details from my table (XYZ table) to Customer Payment Journal(Highlighted Field in Image).
Tell me the possibilities…
Thanks in Advance…
Hello Gopinath,
are you getting issue to connect your table? if yes
you can connect your table using customer id if you have this field in your table ,
Hi Kunal ,
Thanks for ur reply.
I have to use my own customer information instead of existing customer details in AX 2012(CustAccount,Address).There should be a temp table for this report.In that table i have to pass my table values.Tell me the possibilities…
You could achieve what you want, as long as you are maintaining proper technical design & relations with the base tables. In the DP class you could refer your custom tables, based on your design pattern.
Hi Krishna,
Thanks fr ur reply.I have to use the predefined class and tmp table for this.Tell me the class name…
class: CustPaymentJournalDP_NA .
You need to find how the data is being fetched in the DP class.
