Hi
I am new ti AX. I am developing a sales invoice report where i want to print the serial numbers of the item picked in the Picking list.
My problem is the serial numbers i picked in the picking list → Inventory–>Reservation form is not available in the Invent Serial Table rather it s saved in the InventDim table.
Can anyone help me how to get the serial number and Print in the sales invoice report.
–Praveen
I expect you are using a standard sales invoice report…
To add serial number to this report…
AR → setup → Forms → form setup → Invoice -Tab → show in sheet - group → select - serial number.
I am not using standard report. creating a new report.
Then what are the data sources you are using.
If you are using CustInvocieTrans
SerialNumber = InventDim::find(CustInvocieTrans).InventSerialId;
Use the below code in a display method.
CustInvoiceTrans CustInvoiceTrans ;
select CustInvoiceTrans where CustInvoiceTrans.SalesId ==CustInvoiceJour.SalesId && CustInvoiceTrans.InvoiceId == CustInvoiceJour.InvoiceId &&
CustInvoiceTrans.InvoiceDate == CustInvoiceJour.InvoiceDate && CustInvoiceTrans.numberSequenceGroup == CustInvoiceJour.numberSequenceGroup;
inventdim::find(CustInvoiceTrans.InventDimId).inventSerialId;
Arun
